IMM Brush Bug behaviour? (SOLVED)
Zbrush 4 R6 P2 Win7x64
Hi, Well i´m not sure if this bug has been reported before
When you insert a mesh and then press ALT the mesh will stretch. The problem comes later when you try to insert your initial mesh again . The Brush has been modified and now the inserted mesh will be allways the streched one. That´s not really usefull in my oponion. But the funny part is if you change the insert mesh in Brush > Modifiers. The new mesh selected will be same as streched as the previous one. So the IMM Brush is permanently bugged!. But not only the IMM brush you selected is buged. All IMM brushes will be now streched! :frowning:
The only solution is save the project and reinitialize Zbrush.:cry:
Hello
This not a bug. It’s more of a feature to change the sizing of your insert mesh brush. If you want to get the insert mesh back to the original shape just tap the CTRL key when you are drawing out the brush and it will be sized back to the original shape.
FYI…If you continue to hold the CTRL key when drawing out the insert mesh will never become larger then your brush size.
Paul
Thanks heap Paul for taking your time replying this post!
I though it was no other way to get back normal scale in IMM. Now I know after using once IMM with Ctrl pressed all meshes are back to original proportions. So once again not bug at all!:slight_smile:
