imageplane x question
hiyo,
i am trying to learn modeling, i have installed the image plane x file from ZBrush app.
i have it set up and working fine except when i go to manipulate the sphere the image plane is manipulated as well, how do i lock the iplane to isolate it from the sphere?
thanks Z community for all your help,:wink:
Foomoto
What do you mean by “manipulated as well”? Do you mean that it spins and rotates as you do the same with the model that you’re sculpting? If so, that’s exactly the point of the Image Plane X.
On the other hand, if you’re sculpting on one and also deforming the other than it sounds like you don’t have the model set up right. The model needs to be a different SubTool from the X. Also, to scale the model relative to the plane you need to use TransPose or the Size deformation. These affect only the current SubTool.
