how do u upload images in the z brush gallery
When typing a post, you’ll see an “Upload Image or File” button beneath the text entry box. Click that, then follow the instructions. Your image should be a JPG, and must be 200 K or smaller in size.
If you’re using FireFox, it’s a little more complicated. I can give the necessary additional instructions if that’s the case.
i am using firefox
After uploading the image, close the upload window. The Insert button won’t work.
Now look under the text entry box. You’ll see that the image you just uploaded is listed there. Next to the image name you’ll see some code. It looks something like:
{ATT=123456}ImageName.jpg{/ATT}
Except that the { and } are going to be [ and ]. Simply type that code as it’s shown into your post where you want the image to be. When you submit the post, the code will be replaced by the image.
