Image sequence from Zbrush? [Answered]
Hi.
Is there a plugin avalible for R5 to export image sequences from within Zbrush?
Thankyou.
use the movie.export function and tell it to do a .png sequence.
Are you sure? I was not aware that ZBrush renders image sequences. It only renders .mov files. You can select png compression but that is not an image sequence. If I am missing something here, can you please explain how you would do it?
@Daniel-R …I don’t think there are any plugins for that. Most video editors will render .mov to image sequences. I use Sony Vegas and it does a quick and easy render of .mov to image sequence.
Oye, you’re right. I forgot about that whole after effects step.
With Quicktime Pro you can convert the MOV file to an image sequence.
