Image Planes plugin not working?
Hello, I’ve encountered this error while trying to load an image plane (using the image plane plugin)
Zscript Note: Specified memory block could not be found.
[MVarGet.PMData.25]
If I have the image loaded on my texture pane, I will click on the Load Image button but nothing will happen.
Any suggestions?
Thank you!
Using a legit copy of zbrush 4 (someone at school pointed out that could be a problem). On a mac. Image size that I’m trying to load is a jpeg, 150kb. Already tried to reinstall the plugin.
Hmm, that’s interesting. Can you press the Projection Master button, cancel, then try Image Plane again?
