Image planes in Zbrush 4, advice needed please! (answered)
Hi all,
I’m having a problem with image planes I hope you can help with.
I have exported a mesh from 3D Max to Zbrush 4, to help me correct proportions I have set up image planes using the ImagePlaneX that’s in the lightbox under tools. The problem I have with it is scale, it’s tiny in comparison to my original mesh, how do I scale it up?..
…before using the ImagePlaneX I had a go with spotlight which made scale issues no problem at all, however when I press Z to go to my model the spotlight fades out so you can barely see it, is there any way around it?.. so that you can use spotlight for image planes?
I also had a look at image plane 4 but it seems that you can only have one image, rather than having a side/front as with the ImagePlaneX.
If anyone knows of any good workflow tips or tutorials on image planes in Zbrush 4 then please direct me?
Thanks!
Martin
Use the Image Plane 4 plugin.
Thank you!.. the solution was staring me in the face!.. as always :confused:
