Does anybody know what is happening here and how to fix it?
I appended a simple rectangle tool into the image plane and when I rotate stuff disappears. I’ve been trying to figure this out with no avail.
JM
JM
I actually discovered a solution. May not be the best but a solution non the less.
After closing Zbrush I re-opened and then loaded the z tool (rectangle with the image plane) and miraculously everything was normal. No “clipping plane” issues. Although Zbrush is crashing on the simplest of operations like rotating and what not. Save constantly.
JM
Hello. I’d be interested to hear the solution. I am have issues with my object clipping the zplane (canvas) as well. I know that you can manually move the object towards you but, that get’s old. It would be nice if you could just keep the canvas far back that way, if your object is relatively big it still won’t clip when rotating it.
