Image Plane & Projection Master
Hi All,
Just wondering if anyone can answer a question relating to using image plane and projection master.
I’m using some photoreference with a model I’m working on and when I pick up from projection master after modifying the shape of my image plane it seems to be only dropping the texture faintly. It’s as if there’s an RGB intensity setting somewhere that’s turned really low.
What am I doing wrong here?
Cheers!
I think you’ll find it best to switch off ‘Fade’ in the Projection Master dialog.
HTH,
Ah… Thanks marcus, problem solved.
