Does anyone know how to do an ice Cream Swirl such as the image below? I created a helix then went under Initialize tab to play around with the settings but I can’t seem to get it right. Please help. Thank you
I’d probably start with a base cone shape, something to wrap a spiraling curve around. Then I would turn to an IMM brush to insert a star-shaped tube along the curve, and take advantage of it in this state to manually push and pull things around to give it that sense of gravity making it droop in places. Finally I’d fuse it all together, probably with dynamesh, in order to give it a nice polished transition where the icecream melts back into itself, and to make sure the very top looks nice and solid, tapered, etc.
