i think i found a bug with morph targets
I think i found a bug ? in zbrush 4r6 P2 on os x (10.9.4)
i´m not sure if i post to the right thread category - please forgive me if so.
morph target:
• i take a plane
• mask it and the do a polygrouping by mask with polished slider to 1
• i hide the other polygroup
• delete hidden
• then i store a morph target
• i use the transpose line and move it to get volume
• then i click create morph target and switch to that new subtool
sometimes theres a mask stored which can not be cleared by clear mask
i found a workaround:
i make only one polyground of that new object visible and mask a bit of it.
then i show all polygroups, reverse the mask and then i am able to properly clear the
mask
hope that helps
cu cosmic ollie
It seems like morph targets have issues when there are differences in topology. Just wondering why you would store a morph target and add volume after? Doesn’t make sense to me.
hi and thank you for your respond. maybe i didn´t express myself well in the first post.
i´m well aware that i can do this kind of extrusions with other workflows like panel loops,
retopo etc.
here are some screenshots that describes the problem a little bit clearer.
after creating a morph target there´s a mask that can’t be cleared via the normal way.
and it gets visible after you invert the mask.
just selecting / making visible one polygroup - masking a part - then inverting - showing all
polygroups again and then clearing the mask solves that problem.
i´m no noob with zbrush at all - all i can imagine is that this must be a bug ?
kind regards
cosmic
