So when ever I pose out my character and I click TPose>SubT, it poses some of my subtools and gives an error for the others. The error is “error encountered while importing a file.” Does anyone know how to fix this?
Thanks
make sure everything has a unique name, and clear your cache.
Everything does, but I haven’t tried clearing the cache.
Thanks
Did clearing the cache work? I am encountering this exact problem in Z4r2b. Any advice would be great. Thanks
Unfortunately I didn’t try it because I was too close to my deadline and I had to rig it in maya. Something also happened while transferring it to maya and I lost my UVs. You might want to check to see if your UVs are overlapping because I have heard that it can cause a problem.
I tried clearing my cache for transposter master and it didn’t work.
Anybody getting this to work?
W.
Zbrush and transpose master at times doesn’t play well with models who’s base level of subdivision has a high level of triangles. Where this threshold is I’m not sure. Some tris seem to work ok. A lot causes errors. There is an update for transpose master coming soon that improves this but high levels of triangles will still cause errors. I got mine to work by deleting the base subdivision level. (Because once you subdivide, triangles are converted to 4 sided polys).
Wayne
