I need some help with curves and stroke spacing (I already watched zclassroom)
Hi
I recently upgraded to 4R6 and i have some questions
1 What is the correct workflow with drawing multiple curve brushes? Right now i append a new subtool (sphere for example) and draw with tubes curve, then i sibdivide, and then i can draw another curve, is it correct or can i polymesh a curve and draw another in some other more correct way?
2 curve strap brush and curve multi brush work very differently, even though i enabled the SNAP option in both of them, i tested it and curves strap brush snaps to surface better, i tried tweaking the curve snap distance options, are there any other snapping options other than in stroke menu?
3 How can i make the spacing option available? i draw in green what i want to achieve, a cotrolled spacing distance in any alpha.
http://docs.pixologic.com/reference-guide/stroke/modifiers/
" added by certain brush strokes."
could you tell me what are these certain brush strokes?
And what about the curves workflow? am i doing it right? how can i achieve the alpha spacing control i need?
