I modeling with references and I have everything set up with planes and I have my model set up and everything is going good so far. I just need to see through my model so I can finish it. Mostly for the facial details. Can someone assist me. I just need to see through the my model.
Have you used planes appended as subtools? That way is OK but it is only possible to have the planes transparent (so you look through them) not the model.
There are two alternative ways of working with reference images in ZBrush:
- Applying images to the grids. This way the planes revolve with the model. See here:
http://www.pixologic.com/docs/index.php/Reference_Images
- Using the Image Plane plugin. This way the images are in the background and you set up different ‘views’. See here:
http://www.pixologic.com/docs/index.php/Image_Plane
HTH,
Texture->Image Plane->Modifiers->Subtool Transperency
May not be the exact heading names, but you should be able to find it from that.
