So, I initialized zbrush by accident (thought it was something else) and all the menus on the side are gone. Is there a way to get them back? Thanks.
Preferences>config>restore UI.
It doesn’t seem to be working. :\
I download the default config file from that thread. I looked around in my directory for zbrush but I can’t find it. Do you know where I upload the config file on my computer? Thanks.
Did you try clicking next user interface button at top? If the menus are displayed you can easily drag them back to the side trays and then save your config with shift+ctrl+i.
I don’t think that’s the problem.
I went ahead and just reinstalled Zbrush from scratch but it still didn’t fix my problem.
My issue is that when I initialized Zbrush it removed all the default side windows under the TOOL menu and now I can’t get them back. If I use the ‘switch UI’ bottons at the upper right it switches things around but none of my windows return.
How do I get them back on the right hand dock??
Yes, this is my issue. Where’s all my stuff? I uninstalled zbrush and then reinstalled but they’re still gone… :\
This software ‘behaves’ differently than what you’re used to. Without a tool, there is no geometry
Like a moron I just realized the other menus don’t load until I add a tool to the canvas. Durrrrr.
