I Hate Zbrush
i lost many hours and works because it crash when i want to save !!
now my file is corrupted and i can’t refund an old save anywhere…
is there a way to recover a file that i can see previex in lightbox but it won’t open ?
sounds like your tool is too heavy for your system, what are your specs and memory/performance settings?
once its corrupted its gone.
save often and in iterations is the general rule.
ok i’ll take care on future.
i have :
Modèle Dell DXP061
Type PC à base X86
Processeur Intel® Core™2 CPU 6600 @ 2.40GHz, 2394MHz, 2 cœur(s), 2 processeur(s) logique(s)
Version du BIOS/Date Dell Inc. 2.3.1, 23/03/2007
Version SMBIOS 2.3
Répertoire Windows C:\Windows
Répertoire système C:\Windows\system32
Périphérique de démarrage \Device\HarddiskVolume4
Option régionale France
Couche d’abstraction matérielle Version = “6.0.6002.18005”
Utilisateur PC-de-BlackantM\Blackant Master
Fuseaux horaires Paris, Madrid (heure d’été)
Mémoire physique (RAM) installée 2,00
Go
Mémoire physique totale 2,00Go
Mémoire physique disponible 817
Mo
Mémoire virtuelle totale 4,23Go
Mémoire virtuelle disponible 1,75
Go
Espace pour le fichier d’échange 2,29*Go
Fichier d’échange C:\pagefile.sys
where can i see information about size used from ztl ?
well from the looks of it when you copied your system specs
you only had 817 MB available (free) on your system
and only 2 Gb total, maybe… if you can,try to upgrade your ram (get more)
too at less another 2Gb (if you change OS to a 64bit system…more)
