I just redo everything, check SubTools, how can I check model scales?
because I did updated size ratio after that, I set 70 mm height,
I got this.
"Unfortunately, we were not able to process and thus print your product. The error message was:
Your object has not the correct size.
The size is 5694.77 x 7870.42 x 1011.29 cm / 2242.03 x 3098.59 x 398.14 inch.
We can only produce designs from 0.25 x 0.25 x 0.25 cm / 0.098 x 0.098 x 0.098 inch up to 70.00 x 38.00 x 58.00 cm / 27.56 x 14.96 x 22.83 inch (h x w x d).
Please rescale it. "
so how can I fixed it? which SubTools u mean, SubTools Master? or Zbrush’s SubTools?
EDIT
which best export I should use? I just use *.WRL
