i forgot symmetry..
Hi, i`ve got a more or less big problem…
i modelled some details to the hand of my model but forgot to turn symmetry on but need the same details on the other hand…
is there a possibility to copy the details from one hand to another after i sculpted them?
cheers
Simply mask only the side you want to keep and then go to Tool/Deformation/Smart Resym should do the trick.
maybe you can mask the half that u want to keep and than use Sym or ReSym, but be sure you masked the good half of the model and dont forget to save your tool before doing it:lol:
cheers
Smart ReSym will give the best results if you use it at the lowest level of the model and then repeat for each higher level until you reach the max.
