I can't get the "Edge Loop" button active on osX
Hi guys !
I have this strange problem…
I don’t know why but I can’t get the “edge loop” button active.
I use the selection marquee to hide everything but four quads and now I should have the possibility to add a new edge loop by pressing the Edge Loop button. But it’s never active, where did I go wrong ? ( I use version 3.12 on osX )
give the object Uv’s then try
tool>texture>enable UV’s…hmm, that is probably different in the MAC version though…but there should be something somewhere that is similar
Thank you goast666 for the very fast response !
… but it didn’t work …any othe idea !? :slight_smile:
I believe that for the Mac version there is a quirk that you have to have a second subtool visible before the edge loop button becomes active.
Richard
I believe that rjmarklew is correct on that note.
Yeah, you’re right guys, thank you very much!
It’s a little weird because it doesn’t work always…
I really hope that guys at pixologic will remove all these differences between mac and pc version :wink:
thank you again
Been having the same issue (one more) on 3.12, of course, and after a while searching tutos I began to think that I was kinda stupid, or something. Thanks for the trick! One more bug to the collection. When I try to sculpt bugs I mean insects!!!
