I assigned "tilde" to another function. I need the old function back
Hi
I assigned “tilde” to another feature inside Zbrush. However I need that canvas moving function that was originally done by tilda back. Where is that feature-function located? So that I can assign another shortcut.
thanks
In the ZBrush 3\ZStartup\Hotkeys folder you’ll find a text file. Open that file and delete the line where the tilde key has been changed. Then save the file and restart ZBrush.
Aurick so basically if the user assigns tilde to something else it is not possible to call invoke that feature in another way?
I will fix the hotkey file, thanks for the tip.
