Very cool man! One thing that sorta sticks out to me is that the distance from eyebrow to the top of the head seems a bit short, the cranium seems small or squashed. Could be the camera angler/lens, dunno… but overall look good, your getting the skin shader down nicely
could you post the steps you took to get this wonderful skin?
I have the same feeling than bneal…thought it still looks FANTASTIC!
5 stars, I can’t believe you’re not in the top row yet!!
It it all displacment maps or you used bump map as well?
thanks for the comments guys, much appreciated. you guys are right, the head could be pulled a bit higher at the top…simple fix for Zbrush! i’ll get to that in the next couple days.
i decided not to render displacements. the model went up 5 subdivision levels in zbrush, 3 million polys i think. so i brought the level 3 mesh into maya (level 4 mesh kept causing maya to crash on import) so i had a nice res mesh in maya and generated maps off of that from zbrush to get a base for the bump map.
here is a quick rundown, you can follow this tutorial as well to get you started. my little write up sort of assumes you know a little bit about the shader. if you dont’, you can learn from this tutorial http://forums.cgsociety.org/showthread.php?t=214189
i’m using the maya_fast_skin shader in mental ray for maya
in the lightmap check the ‘local’ checkbox and type in a path to a the file. most people, and if you read gpepper’s tutorial at the link above, will just put c:\sss but…for some reason i wouldnt’ get any sss unless i put c:\sss.tif
thanks for the info on that ZippZopp, I had to do the same thing when i made the SSS file but I did SSS.map not that it would make much a differnce but it could cut back some of rendertimes
maybe. I had been putting the spec map in the overall weight, ill try putting in the spec color and tinting it blue.
thanks again that was big help.
Great work!
I am reading more and more about these different SSS shaders for Maya and XSI however I have not been able to find a resources regarding Max’s variation. I was curious if anyone could point me into the right direction for achieving this type of skin shader in Max.
not sure how the shaders and things work in max, but i know of a few renderers which i always see producing nice results. look into Vray and Splutterfish’s Brazil for Max. i’m sure those have their own options for skin shaders
