Howe to scale an object for 3D printing, not
I am using Zbrush 3.1 to make some accessories or weapons for toy figures.
The problem I can’t work with a scale in Zbrush to say that the diameter of the sword handle is 2 mm to fit in a hand, to set the size of an armour to fit around the chest,etc. For example, for armor I want to scan in a figure and make a new armour by extracting. The new part would fit perfectly if I could state somewhere the exact sizes or a referencing saying the hand is 1 cm and the should be scaled accordingly.
I know about the new plug in for 3.5 , but i understand you can only set the height of the model you want to print
What do you use to properly scale things made.
Any other software you import the mesh into?
Cheers,
Johan
