Hi
I am new to zbrush. I have tried looking online for my solution and i havent found it. so heres my problem. when i hold down my left mouse button and hold down shift then i can scuplt straight lines. but i would like be able to hold down shift and be able to scuplt lines at a specific angle like 30 degrees or 40 degrees instead of 90 degrees. I also looked under the stroke modifiers and under the curve features i found the as line feature. It allows me to trace out a line which is what i am looking for but once i decide to let go and assume that a straight feature would be extruded from the traced line this does not occur. I am wondering if i am not using the feature correctly or if there is an alternate way of doing this please let me know
