how to use mirror in zbrush?
I have a problem while sculpting the face. The transform symmetry didnt following it correctly. And I am not sure how to use the mirror function in deformation window. It keeping it saying “note: this function can not be applied to a mesh with multiplie subd levels.” Someone else know how?
Are you trying to flip your mesh to the mirror image or re-introduce symmetry?
If you are trying to reintroduce symmetry, try the following:
Make sure only an object that should be symmetrical is visible. Hit Transform -> S. Pivot. This will put the pivot in the geographic middle of what is visible.
Now, mask the half of the heads you like, leaving the “broken half” unmasked.
Go to Tools -> Deformation -> Smart Resym. Make sure that only the little “x” on the right side of the button is highlighted. This will attempt to re-adjust the symmetry of the unmasked part, using the masked part as the template.
HTH,
-K
Mask off the half of your mesh that looks good, then hit Smart Resym, then clear your mask.
Hello again since it is same topic problem I decided to post one more help here.
I have used twice the smart resym. And it seems it doesnt work anymore when I tried to smart resym the hand. “Symmetri points not found symmetry map was not stored.” I followed ur words masked the other hand and hide the body to make smart resym.
