how to use an image like reference to mold? in zbrush
In this video of youtube one sees as but the linen cloth is only seen and not them herrramientas that uses, not that steps follow, only sees the result.
http://www.youtube.com/watch?v=UPCYFcuxOZQ
tool>load tool>imageplane X, or imagecube x.
there is a .psd with both of these files…set up your images based off that file
apply the texture
divide
txt>col
remove texture
append a new subtool
turn on Transp
tada
I fail to turn on transparency, where this option?
if you have the default UI then it is on the right hand side, under FRAME and above LASSO…i think
Ok, thanks a lot goast666, me now works perfect
