hi there! im not using projection master just using the drag brush with alpha texture, it seem projecting it to the back as inverted effect. is there a setting turn it off or just mask the back of the mesh?
If you are using ZBrush 3.1, make use of the Backface Masking feature which is found in the Brush palette.
