I’m trying to sculpt fish scales with an alpha using the standard brush and drag dot stroke.However it’s dificult to accurately align the stokes when they are rotating.How can I stop the rotation happening?I’m aware of the shift key constraining the movement to 90deg or 45deg but I want to freely move the stroke around without rotation.
You may need to use Projection Master. When in 2.5D mode, you can edit the most recent stroke. So you can draw and place your scales, then immediately press R to activate the gyro and rotate the stroke.
