when i import the mesh in max it leaves a tiny bump there anyway to remove these
del lower res…maybe?
this is the low res
i ran the remesh command but idk why it creates these points
Actually it sort of has to at some point. I think…
You are working with quads (inherently squarish) in a rounded bit of mesh, at some point it has to go from square to round. In theory you could retopologize it by hand or by using the Topology Brush, but Im not sure what you are working with there so, are other parts hidden?
nothing else is hidden, only this one surface, all i needs is the small bumps gone but its a tough thing
