I spent some time a while ago customizing my interface colors. I temporarily need to revert to the default color scheme. How do I do this? I can’t find a “default” file in my ZBrush directory.
Thanks,
Greg Smith
Thanks,
Greg Smith
This will help you
interface color
standard interface
The IColor Manager ZScript provides the default colors.
Alternatively, temporarily rename UICustom.cfg in your ZBrush folder.
Bruce,
i dont know of any other way then preferences>config>load ui then rename uicustom.cfg file to example myuicustom.cfg.
this sets default ui then change name back
to uicustom cfg. and reload
three replys at same time,what a place zbc!!!
Hi
Here is one more (but yet undocumented) method to restore the interface colors without losing other preferences (such as palettes layout).
If satisfied, you may save your reconfigured interface by pressing CTRL+I
Hope this helps
-Pixolator
Thank you very much, all. So, you really don’t need to save the default color scheme since it is so easily restored. Only the ones you modify and wish to keep.
Greg Smith
(but yet undocument) any more cards up your sleeve
