How to quick select subtool in 3.5?
It seems that shift + ctlr and click on a subtool that you want does not work anymore. Is there a different way of doing this now?
Also the hotkey “b” does not work as well. It would move to the 1st subtool when you press “b”
It has changed to simply holding the ALT key and clicking on a subtool on the canvas. I was afraid this would cause problems as most 3d edit mode brushes use the ALT key to reverse the brush effect. But luckily, or rather thanks to the glowing minds at Pixologic:), the ALT+click subtool detection is much improved from 3.1.
Thanks TVeyes. Sweet that does work pretty good.
Oh… did you read my other post? http://www.zbrushcentral.com/zbc/showthread.php?t=75058
I hope you got a solution for me on that as well…
