how to permanently alter the zadd setting for default Smooth brush?
Greetings,
I would like topermanently alter the Default Smooth brush settings so that it will load the altered settings when zb starts up.
I know how to save custom brushes and put it in the startup folder; but a custom smooth brush will not transfer to the “Shift” shortcut.
I like using Shift a lot to smooth meshes but the startup smooth brush is always set to 100 intensity. How do I permanently alter it?
Regards,
Vincent.
What you could do is record a macro of you selecting the Smooth brush, changing the Zadd to what you want, and then returning to the Standard brush. After recording the macro you can add its button to your shelf or you can assign a hotkey to it. This isn’t quite the same as having the setting load at launch, but it’s darned close!
