How to open an insertmultimesh brush to add additional subtools and reorient?
You need to use the Tool>Geometry>MeshFromBrush button. This replaces the current subtool with the selected brush mesh. You need to go through them all and then create a new IMM brush after making your adjustments.
This macro will make converting the brush to subtools easier. Copy the file to your ZBrush 4R7\ZStartup\Macros\Misc folder and then press Macro>Reload All Macros or restart ZBrush. Select the Polymesh3D Star tool, put it in Edit mode and then select the brush you want to convert. Then press the Meshes From IMM macro button.
thanks for the script!
