How to move an Alpha over a mesh? [tips&tricks]
Hello,
Is there a way to move an alpha over a mesh after you have dragged it?
Like if I want to center an alpha perfectly on something it can be hard if you can only drag. Is there a special way to move an alpha?
Ty
You can use the Drag Dot stroke. You’ll need to set the Draw Size to the size that you want the alpha to be.
Thanks a lot!
Hey Is there a way to move the alpha without having it spinning?
Yes, in the Stroke menu turn on Backtrack, Snap To Track and Line. Now if you drag your mouse downwards a red line will appear with a green crossbar at either end. You can adjust the line so that it is vertical if you hold Shift after you start the drag. Once you’ve finished dragging downwards drag back up again and the alpha will appear. You can drag upwards until it’s in the position you want.
Hey thank you marcus these are some rly good advices I needed!
