how to make stitch brush go around
hi guy,
im having problem with stitch brush. I’m trying to make stitch pattern along the eye patch line as you can see in the image. What’s the best way to make it ?
Trying to brush it right onto the object seem fail, since you make to rotate the object at one point and not to mention changes in brush pressure once we let go of the wacom :( Thank you guys. [<img src="http://www.zbrushcentral.com/pixo/atn.gif">](http://www.zbrushcentral.com/zbc/faq.php?faq=vb_read_and_post#faq_zbc_display_images)
-Turn off “use tablet” in zbrush preferences. (This will disable pressure sensitivity until you turn it back on.)
-Do not scale (zoom) the model until you are completely finished.
**It is safe to rotate the model.
Thanxs for the reply i will try that :slight_smile:
