How to make eyelashes with curve tubes
How would you make eyelashes with curvetubes? Most of the videos I have seen of curvetubes when you adjust the brush size it does the entire tube length rather than section of the tube. Also if you could do this, would there be a way of duplicating the curve, making slight adjustments and transpose movement, than adding more curves? One eyelash be a bit weird. :lol:
Hi :wink:
would that help you?
EyelashesCurve Brush:
http://www.zbrushcentral.com/showthread.php?170167-Insert-Multi-Mesh-Repository/page17
scroll down pls.
Christian
It looks useful. But not quite what I had in mind. I want to make non realistic eyelashes which are large and evenly spaced. This technique should help with making tails as well as stylized fingers. Tapered curves essentially. This brush looks helpful realistic characters though.
