How to keep UI changes after restart.
Tried a couple times to rearrange my UI, but it keeps changing it back to default when I restart ZBrush.
Is there a post somewhere or could someone tell me the steps needed to make my UI changes stick around?
Thanks.
PS I know this has probably been covered, but there are so many forums and so many posts, I am not even sure what the best search phrase would be to locate the answer…
Once you have your custom UI set, Go to Preferences> Config> Store Config. That will then become your startup config.
While you’re there, hit “Save UI” and save out a copy of that UI so you can recall it quickly in the event anything gets changed.
MANY thanks! Will do that ASAP!
