Hi there,
you have a situation in which your work needs you to alternate between lets say 3 different brushes. The brushes need to have different draw sizes, like brush one needs to be size 20 while the brush two needs to be size 50. Is there a way to keep the last used draw size? So instead of selecting the brush, adjusting draw size, draw, then change brush, adjust draw size back, then draw and so on, i am looking for a way to keep the size parameter for the brush, so its adjusted automaticly when reselected. Is that option in zBrush available, maybe even for other parameters too?
Best regards,
Bildermensch
I think ZBrush2018 has that option of saving draw/brush size.
Go to References>Draw, under the “Dynamic Brush Scale” slider, there are two icons/buttons. The one on the left is “Remember Dynamic Mode Per Brush”, the one on the right is “Remember Draw Size Per Brush.” Those two buttons are also located in the top shelf (default) next to “Focal Shift/Draw Size.”
Thank you I will try that!
Regards,
Heiner
