Hi!
Is there a way to increase the Alpha, make 3D Mres resolution slider higher than the current maximum. I’m thinking about like changing a value in a config file if possible or something like that, thank you in advance.
Hi!
Hello @Dr.Kacor!
Not to my knowledge. If your alpha is abnormally small, you might try increasing its size for sharper detail.
Likewise you could use the Spotlight Snapshot 3d feature to create your mesh instead. The larger you scale the alpha prior to snap-shotting it, the higher the rez will be.
Actually it’s a 4K 16-bit heightmap and I got already quite a good result. The mesh has about a million point and it generates very fast so I wanted to try out with higher resolution, probably it would retain crisper details
