how to extrude in zbrush
help me pl tel how to extrude and to seprate it as a sub tool in zbrush
pl if any hellp i would be greate full thanks
hey dude, i will try to explain you that, you have to make a mask in the area that you want to extrude, reverse the mask and after that in the deformation tab you use the taper or the inflat and make the extrution, after that you have to select that part and put it into a polygroup,then hit in the subtool tab GrpSplit, i think that should work…
:+1:small_orange_diamond:+1:
Please see the online documentation. The link is in my signature. It explains things step by step.
i have also the same problem!! =(
how to do that exactly??
