How to export a cavity map?
In Zb 4 I could mask by cavity, make alpha, export the map.
In Zb 4 r2 I get a black screen with some white spots. I tried blur on masking, density etc… all worked fine on screen but still get this black map. Similar for AO masking.
On the mac zb4r2 build.
Currently the create maps from masking functions do not work properly. Until this is corrected in an update, one way would be to use polypaint to fill the model while masked, then use Texture>New from Polypaint.
Thanks marcus.
I was guessing this. Still, the new masking method is more capable for good results.
