Hi!
How can I edit a set of insert multi mesh brush? I’d like to delete useless or duplicated meshes from set it’s realy big set to create new instead of delete meshes.
probably you may want to mantain the default as they are…then save the one you want to made changes with aanother name in other folder so you can make a new one
here is a zscript recording session that i wish can help you
