How to draw multiple IMM curves?
Hello,
I am familiarizing myself with IMM curves, and I cannot figure out how to draw multiple curves.
Im working on a hard surface model and want to have a lot of hoses and tubing throughout the model, but it is not a dynamesh (dynamesh would create too high res of a model for my needs).
When I try to draw multiple curves, such as a bunch of hoses, each new curve replaces the previous one.
The only way I’ve been able to work around this, so far, is to draw my single hose curve, split by polygroups, then continue onto the next curve. But, by doing this, I loose all undo history since its a new subtool, and cannot use the record history forward option.
Have I missed something that would fix this?
Any help or suggestions would be greatly appreciated!
On a side note, ZB seems to crash much more frequently while using a IMM curve. No recovery file, just crashes.
Thank you in advance!
After you draw your curve, click once on the underlying mesh. Then draw your next curve.
Hah, I didnt think it would be such a simple thing…here I am, tearing through every menu :lol:
Thank you, that solved my problem.
:+1:small_orange_diamond:)
It doesn’t hurt to see what’s in all those menus. :slight_smile:
