how to do with multiple objs??
hi!
I’m working on a project in which one i’ve several objects to bring.
1/ does anyone has already done multiple export of objs. in xsi to zbrush?
2/ if i bring an obj with severals merged meshes, do i have the possibility to split this obj. with polygroups and make each part a single tool?
for example, with the image below, i could bring this mesh in one obj merged.
Can i extract all polygroups and make each element a tool?
here is the image. If you can help me, it would be great!!!
](javascript:zb_insimg(‘141621’,‘WIP_LNM05_low.jpg’,1,0))
xsi
select everything you want to export
export out an obj (merge all)
zbrush.
import the mesh
tool>polygroups>autogroup
tool>geometry>groupsplit
thanks a lot!!!
i’m gonna try that as soon as i can!
You can also export multiple OBJ’s out of your other app, then use SubTool Master to batch import them. This will combine them all into one model with multiple SubTools.
