How to do this???
Hello every one, I was just wondering how to apply texture with dragreact stroke, as shown at this youtube video (0.10 sec)?
http://www.youtube.com/watch?v=U0KlhlLUlPE
Also, I don’t know if am i’m allowed to put this video since it’s not mine, so tell me:)
Well…the video doesn’t link.
But…if you disable UVs
tool>texture>disableUV
Then apply a texture, you can use that as the texture stroke.
You can also use a texture inside of Projection Master as well.
Sorry about the link:confused:
Thank’s for the advice, it really helped. You are a life saver mate, thank you one more time.:smiley:
One more thing, when I’m done with polypainting and I want to make that color into texture; how do I do it? When I hit enable UV and col>tex it’s all black.
you’ll need to import your UV’s again. “Disable UV’s” should be called destroy. It totally deletes them.
Just go to level 1
tool>morph target>StoreMT
tool>import (grab original mesh with UV’s)
if the model doesn’t move you should be fine, and you now have your UV’s back. Col>txr will work again.
If the model does move, then…
tool>morphTarget>switch
tool>morphTarget>delete
Now you should be all set.
You’ll want to step up a division or two after importing the UV’s to make sure that the mesh doesn’t explode.
Happy to help
Man, I can’t thank you enough :D:D:D
