ciao, non riesco a creare un’ armatura, non so proprio da dove partire.
Mi potete aiutare? perfavore
hello, I can not create an armor, i do not know where to start.
Can you help me? please
thanks
thanks
if your a beginner one way is the extract option in the subtool menu, use the masking option (control key) - x symmetry for
same on both sides to draw where you want armor and extract, try different thickness settings, when you have something you like accept - it will be the next subtool in menu - click on it and continue sculpting ! theres also the topo brush and retopo tool for more advanced users - hope that helps ! have fun
Grazie Gary, ho una domanda, non posso usare il brush retopo quando ho una suddivisione geometrica per le mesh organiche.
Come posso fare?
Per le mesh organiche posso usare dynamesh?
grazie
Thanks Gary, I have a question, I can not use the retopo brush when i use a geometry subdivision…
How can I do?
Can I use dynamesh for organic mesh?
thanks
ps. Sorry for my bad english
there are several things you can not use with sud div levels - but you can clone your model - freeze or delete higher and lower
div levels then append the (armor) to the sub div model,but in the end you will want the accessories on the detailed model anyways ? dyna mesh redistributes polys to stretched out parts usually appendages on organic models and such.
