I have a problem with opacity while masking. Below is what i get when masking with mouse (Left). And next to it is what i want, solid uniform mask(Right). What properties should i tweak in order to achieve it?
When it comes to actually painting the mask, make sure the RGB Intensity is maxed as you hold down ctrl (also check the focal shift setting and any alpha image to make sure its not being affected by a falloff).
If you mean the actual display of the mask regardless of its strength, then Preferences: Edit: Masked Object Dimming can help (though you’re not given many options on the slider).
