How to change the "start up" document size
Hi PixoPeeps,
I recently got a new monitor with more resolution, and now when I start up Z Brush the document size is so small. I have to resize it each time I open up Z. Is there a way to change the default document size at start up? I need it to be bigger (see picture)
Also, why I am on the topic, can I also get rid of the sphere primitive that loads by default?
I am running OSX if this matters.
Any tips are appreciated.
e~
You can create a Startup document. Simply set up the document how you want and then save the file in the ZStartup folder as StartupDocument.zbr
See here for more information:
http://www.pixologic.com/docs/index.php/Startup_Document
Note: for users of ZBrush 3.5 R3 for Windows, a Startup document will currently cause problems with ZAppLink.
Thank you, Marcus.
