How to change the root zphere?
Because I create the zphere start by by the chest, but after all figure done. When I want to change to pose it. The hip is the better root zphere(pivot) is hip.
So, how to change the root zphere from the chest to hip.
I’m afraid it’s not possible.
surely this can still be done, i mean digits old script for z2 even worked in 3.5r3, why can’t a simple plugin for this be written along with copying and pasting chains, i know tveyes was working on a zsphere plug (not sure if it included this).
Although it may be possible to write a plugin that’s not really at issue here I think. As things are, there’s no way to change the root zsphere. The user will learn from the experience. (And anyway there were issues with zscripting zspheres so scripting a ‘simple plugin’ is actually not that trivial.)
Thanks, marcus_civis and spaceboy412. I try to find some plugin like elf for zphere, but there are no the option for the change the root zphere.
But I still believe change the root zphere is very important, because when you really do animation, the pivot is very important part for it.
