How to avoid GOZ Max changing to Mental ray renderer
How to avoid GOZ Max changing to Mental ray renderer and materials?
When using Vray this is rather annoying.
Maybe this will help: http://trixigt.com/goz-to-vray-renderer-and-vraymat-in-3ds-maxscript-fix/
Thanks. I wonder if somebody has used it recently with the last versions of Max and Zbrush as it is from 2013.
I looked around a little bit and that was the most recent thing I could find. Everything else was from 2011/2012. I don’t use Vray so I don’t have any way to test it myself. Maybe you can contact the author and ask him if he has an updated version?
Or you could try saving your Vray settings and then reload them after GoZ, as mentioned here: http://www.polycount.com/forum/showthread.php?t=140419
Thanks
