How to apply specular maps?
I’m using zbrush 4 and trying for the first time to really have a go at shading in zbrush.
In the material modifiers tab, I can select between 1 and 4 shaders, and at the bottom of each one there are 4 colour/texture modifiers. I can change the colour texture, and the colour tab of all 4 slots, but can’t add a texture to any others - they appear greyed out.
This is with the tri, quad, and any other shader I’ve looked at - is there something I have to ebnable?
thanks,
gubar
Specular maps can not be applied in Zbrush.
thanks for the reply.
It is strange that the box marked “spec” has a texture slot beneath it. You just can’t use it it seems.
cheers
g
you can use an image but it isn’t applied with a UV map it is a simple projection that will be applied and will most likely not provide the effect you’re looking for when thinking of a spec map.
