I have a question, how can i aplly an eart alpha map to a sphere in projectmaster ?
Is there a possibility, if so : what tool should i use ?
I add an example of the image (low quality)
Best Regards, Luckske
Why use PM? Why not just give spherical UV mapping to the sphere so that the map wraps correctly? As long as the map is mercator projection, spherical UV mapping will do the job.
